Yes, you can use our free utility called ?probeManager? to update multiple AKCP units that are connected to your network simultaneously. If you not sure how to use the probeManager utility, contact technical support. The probeManager utility has also been added to our securityServer software, so this can be launched and used right from the securityServers GUI. You can also use probeManager to get multiple backup files from the units and also load these backup files back to the units. This can be used for mass deployment of multiple AKCP units (as long as they are the same model of unit).
