connect AKCP monitoring to UPS? You can use our 80 virtual sensors feature included in the securityProbe device that allows you to perform an SNMP get command on any SNMp enabled network device. If your UPS is network enabled and is SNMP compliant, you just need the OID for polling the battery data and you can monitor the battery status on the UPS from the securityprobe. You can also tie into the SEC notifications as well
