I am trying to have another device listen for the MQTT data from an SP2+ rack temp setup. I can tell it which IP (or name) and port number, but can’t seem to control what topic it sends the data on. That’s fine, but I then need to tell the other side what topic to listen for.
Any insights????
- narwhal asked 1 year ago
Hello,
Did you happen to check the MQTT manual yet? If not this includes all of the steps for setting this up on our units. Here is the direct link;
http://www.akcp.in.th/downloads/Manuals/MQTT/SP+%20and%20WTG%20MQTT%20Manual.pdf
Also, make sure the firmware is updated to the latest on our website support portal;
If you have any further issues after checking the above, please contact our support team;
Regards,
-AKCP Support Team
- asfscott answered 1 year ago
