Hello, I want to monitor a ASCO ATS monitor in my AKCP device. I have verified through a MIB walk I should be able to run a GET against the other device, but I am having issues getting the virtual sensor setup. I am showing the following values in a MIB WALK.
MIB OID Name Value
ASCOSNMP-934904-001 1.3.6.1.4.1.7777.1.1.4.0 devices.1.4.0 1
I would also want to monitor the next value down and a few more. Any recommendations?
- awilliamsmj asked 4 months ago
Hello,
Please check out our latest OID manual and use our latest MIB file as well here on our website support portal;
http://www.akcp.in.th/downloads/Manuals/AKCP%20OID/AKCP%20SNMP%20OID%20Manual.pdf
http://www.akcp.in.th/downloads/Manuals/AKCP%20OID/akcp.mib
Also, you can always find each and every sensor OID from the “GET SNMP OID” button on the left column after clicking on the sensor in the units web UI.
You would also need to make sure the firmware on your AKCP base unit is upgraded to the latest on our website support portal.
Regards,
- Mot answered 4 months ago
