0
0
Hello, good morning. I would like to know how to connect my AKCP SP2+ to Mosquitto and see the reflected data there, because when I tried to do it, it didn’t work. Could you please provide me with the steps to do this and then take it to Node-RED to view the data? Thank you. please provide me a tutorial or pdf
atte
ROLANDO GARCIA
  • You must to post comments
0
0
I’ve contacted the support, they should answer shortly.
I know that the team is planning to add some MQTT (Mosquitto) features.
Gabriel St-Pierre Lemieux
PhD Chemical Engineering
Researcher for AKCP, https://www.akcp.com/
0
0
Hello Rolando,
Please use the link here below & instructions to access our support portal where you can download our updated MQTT manual for the SP+ units.
Setup of AKCP Support Page manual
Please let me know how this goes and if you have any further questions, please contact me via email here: [email protected]
Thanks,
Scott
Showing 2 results
Your Answer
Please first to submit.
AKCPmqtt for mosquitto and them node red
