Can you meassure DC current with this product?
Or it is only current AC?
Hello,
No, our CCM can only measure the AC current. You can use our BattMon sensor for measuring the DC current.
https://www.akcp.com/akcp-products/battery-monitoring-sensor/
Thanks,
Regards,
- asfscott answered 4 months ago
Dear AKCP Customers,
Also, we wanted to add some more useful technical details regarding our CCM. Please see below for the Q&A’s.
Question: What size of cable is supported on the CCM?
Answer: We support cables up to 12.12mm in diameter. If the cable has a larger diameter then it is incompatible with the CCM.
Question: Can the CCM measure the current of a 3-phase system?
Answer: Yes, if the cable size is compatible, then it can be measured.
Question: What is the maximum measurement from the CCM?
Answer: 20 Amps.
Question: Do you happen to have a video on how to setup and calibrate the CCM?
Answer: Yes we do, here is the link to the YouTube video:
Thank you,
