0
0
Hello AKCP,
Is your AKCP CCM, or Contactless Current Meter compatible with the AKCP sensorProbe or securityProbe base units? And how do I install this sensor?
Thanks
  • You must to post comments
0
0
Hello,
Thanks for your questions. Our AKCP CCM is only compatible with the AKCP SP+ H7 type base units.
Regarding the setup and configuration, this is covered in detail in our e-Learning video here; https://youtu.be/Ns59yh9Q1SY?si=h3_e2BPdTW864f1k
Important note: You will need to ensure you SP+ base unit is running the latest firmware that is available on our website support portal here;
Showing 1 result
Your Answer
Please first to submit.
AKCPCCM or your Contactless Current Meter Sensor
