AKCP Server Room Power Monitoring
power-usage-effectiveness
Monitor Phase Line Voltages, Current, Power Factor, Active Energy and Active Power
Lower IT energy bills with Power Monitoring Sensors.
Monitor power usage in server cabinets.
Using Power Monitoring Sensors, AKCP automatically calculates the efficiency of server room cabinets. Using efficiency data, you can make calculated changes to the way your server room works. Optimize your infrastructure and save money in the process.
30%
Monitor PUE in real time.
Power Monitoring Sensors Measure the power consumed by IT and non-IT power enables operators to benchmark and compare power consumption from a single or distributed deployment through Power Usage Effectiveness or PUE calculations.
Evaluate future cost-saving measures using the initial PUE benchmark. PUE and other server room metrics can be tracked over time to help identify server room issues and opportunities for cost savings.
Automatic PUE calculations.
Calculate PUE values using data polled from numerous devices. A real time PUE value can be displayed rack by rack or for an entire server room. Power Monitoring sensors collect all the data from IT and non-IT loads that are used in this calculation.
Did you know? Many SMEs use distributed server room deployments instead of a single server room. Smaller wire closet rooms are less energy efficient with typical PUE values of 2.5
*Study by Berkeley Lab, Improving Energy Efficiency for Server Rooms and Closets.
PUE cost savings : Server Room vs Wire Closet
In the study “Improving Energy Efficiency for Server Rooms and Closets” from Berkeley Lab they explain how an IT administrator for a medium sized company has ~10 servers, each consuming 500W. A cost comparison can be drawn between a using a wire closet setup and server room configuration using PUE calculations.
This example assumes the cost of electricity is $0.12 per kilowatt-hour (kWh). While the servers are using the same amount of energy, the costs associated with powering the room varies based on the PUE efficiency of the cooling and power infrastructure. By consolidating server racks to a central server room location you can better control cooling help to save on operating costs from day one. Monitoring the power consumed by IT and non-IT infrastructure is a crucial element of an IT deployment.
Monitor Power using AKCP Virtual Sensors.
Use AKCP Virtual Sensors to integrate and monitor IT power from any MODBUS or SNMP enabled device such as a UPS, CRAC or PDU.
Virtual Sensors can be monitored locally on an AKCP Platform or the AKCPro Server DCIM.
Create SNMP Get, Custom Scripts, MODBUS TCP, PING and Multiple (Boolean) Virtual Sensors.
 Use AKCP Graphing to monitor PUE fluctuations over time.
PUE-Wiring-Closet
Temperature-Wiring-Closet
